Einleitung
This is a three part Lower Unit Service on a Johnson 40 boat motor. Model Number: J40ELERE
Was du brauchst
Remove the cotter pin that is stuck through the propeller shaft using a pair of pliers.
If the washer behind the propeller did not come off with the propeller, remove it and set it aside with the propeller, other washer, and castle nut.
Remove the two screws on either side holding the anode in place using a 5/16 nut driver.
Remove upper cowl by turning the black levers on the front and rear of the cowl
Remove the lower cowl by removing the one 3/8 in bolt from the front
the two 3/8 in bolts from the rear of the lower cowl
the 3/8 in bolt under the bottom of the lower cowl. This is most easily done using a universal-joint socket.
Trim the engine all the way up and pull the two halves away from the engine and downward, removing the rubber holders for the battery connection and control cables
Remove the 3/8 in screw connecting the vertical shift linkage going into the lower unit to the horizontal shift linkage in the upper unit. This Is located directly below the block on the port side of the engine.
Remove the four 9/16 in bolts connecting the lower unit to the upper unit. This will need to be done with a regular wrench.
Remove the one 5/8 in bolt holding the lower unit to the upper unit. This is located directly above the propeller. As you do this the lower unit will begin to pull away from the upper unit.
Remove the lower unit from the upper unit by gently pulling the lower unit straight away from upper unit, taking care not to bend the shaft or shift linkage.
8. Place the lower unit on a table or put it up in a vice if one is available. This needs to be a clutter free workspace to ensure that the small parts in the water pump can be found if dropped
Remove the outer water pump housing by sliding it up the shaft. This should expose the inner housing.
Remove the inner housing. The impeller should be stuck tightly inside the inner housing and will come off with it.
To replace the impeller and inner housing, first put the key into the notch on the shaft and slide the impeller and inner housing down the shaft lining up the key with the notch on the impeller.
Slide the housing down the shaft and make sure the seal for the outer housing is sitting in the grove on the underside of the outer housing.
To finish installation, follow the removal steps in reverse starting at step 9
2 weitere Personen haben diese Anleitung absolviert.
