Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show how to lubricate the power dial. Your power dial will operate smooth after completing this guide.
  1. Unplug the device before proceeding. Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
  2. Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
    • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
    • Remove the cord from the phone base.
  3. Use finger to remove the battery cover. Use finger to remove the battery cover.
    • Use finger to remove the battery cover.
  4. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Remove the Volume Dial by gently grasping the dial and pulling away from the base. Remove the Volume Dial by gently grasping the dial and pulling away from the base.
    • Remove the Volume Dial by gently grasping the dial and pulling away from the base.
  6. Remove the 6 screws from the base shell.
    • Remove the 6 screws from the base shell.
    • Remove the 3 12mm screws with the Philips head #1 screw driver.
    • Remove the 3 18mm screws with the Philips head #1 screw driver.
  7. Pry off the base shell using a Plastic Opener Tool. Pry off the base shell using a Plastic Opener Tool.
    • Pry off the base shell using a Plastic Opener Tool.
  8. Inside base shell on circuit board, lubricate power switch.
    • Inside base shell on circuit board, lubricate power switch.
    • CAUTION: Make sure lubricant does not circuit board. This can damage the circuit board.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Norberto Sanchez
70 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 16-59, Forte Fall 2012 Mitglied von Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 723
