Zum Hauptinhalt wechseln
Lytro Camera First Generation Repair
Was du brauchst
  1. Lytro Camera First Generation Repair, Lytro Camera First Generation Lens: Schritt 1, Bild 1 von 1
    • Pull the top off using your hands or the plastic opening tool.
  2. Lytro Camera First Generation Repair: Schritt 2, Bild 1 von 1
    • Unscrew the four screws(7.1cm) seen after taking the top off.
  3. Lytro Camera First Generation Repair: Schritt 3, Bild 1 von 1
    • Pry that silver piece off that you just took the four screws out of.
  4. Lytro Camera First Generation Repair: Schritt 4, Bild 1 von 1
    • Take the camera out of the red part. You should have 3 piece not including the top.
  5. Lytro Camera First Generation Repair: Schritt 5, Bild 1 von 1
    • Take the 3 screws(.5) out of the middle piece.
  6. Lytro Camera First Generation Repair: Schritt 6, Bild 1 von 1
    • After taking that off you will see the camera lens.
  7. Lytro Camera First Generation Repair: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Pry the piece hanging off with tweezers.
  8. Lytro Camera First Generation Repair: Schritt 8, Bild 1 von 1
    • Now you can unscrew the three screws(.5) seen releasing the camera lense from the camera.
  9. Lytro Camera First Generation Repair: Schritt 9, Bild 1 von 1
    • After that you can pull it off with the tweezers.
  10. Lytro Camera First Generation Repair: Schritt 10, Bild 1 von 1
    • Now that you have it off you can replace it and reverse the steps getting it back together.
Abschluss
Jeremiah Killam-Hull
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 496
