Einleitung
The nozzle is where the M3D's filament is extruded from, so it's a crucial component. If something is wrong with your nozzle, it's likely that your printer won't function properly. Luckily, the M3D Store sells a replacement nozzle that you can easily substitute for the faulty nozzle on your machine. The nozzle is easily accessible and as such, easy and quick to replace.
Was du brauchst
To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
Disconnect the red and black wires at the white connector. They should easily separate.
The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
To remove the nozzle insulation, grip the insulation and pull it up off of the nozzle.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
