Einleitung
When "Ink Absorber Full" or "Ink Absorber Near Full" appears on your printer screen, it's time to replace the Ink Absorber Box (and/or the Flushing Box).
Was du brauchst
Open the front access door and remove any cards or cables present. Close the access door.
Remove the paper tray.
Remove the ink cartridges.
Open the printer cover using the finger holds on the sides.
Unplug and remove any cords present under the cover.
Remove the LAN port and EXT port caps (if present).
While holding the cover with one hand, pull the hook on the back of the support damper, then remove the damper from the cover.
Remove the damper from the support.
Turn the support upright and pull it straight out of the printer.
Use your finger or a spudger to unhook the two tabs on the right side of the harness cover by levering it up.
Remove the harness cover. There are two tabs on the left side that you have to wiggle free, and one on the front.
Remove the 6 mm Phillips #2 screw from the grounding wire of the ADF motor harness.
In the proceeding steps, you will disconnect the following cables:
CIS flat cable
Scanner motor harness
ADF motor harness
Document detection/document scanning position sensor harness
Pull the document detection/document scanning position sensor harness out of its sockets.
Insert a spudger between the scanner harness holder and frame to release the tab. There is a second tab on the opposite side.
Lift the scanner harness holder out of its frame.
Push on the tab to secure the scanner harness holder to the scanner cover.
De-route the document detection/document scanning position sensor harness and the ADF motor harness from the scanner harness holder.
Using both hands, pull the scanner cover to the rear while holding it vertically, then lift it off of the printer.
Remove the six 12 mm Phillips #2 screws securing the upper cover to the printer.
Pull off the upper cover.
Remove the ink absorber full sensor from its socket.
De-route the wiring from its harness.
Unclip the ink absorber from the harness by pulling it up and to the right.
Remove the drain tube and the air vent tube from the ink absorber box. A spudger may be helpful.
Clip the ends of the tubes so they won't leak.
De-route the tubes from the holder.
Rotate the ink absorber box 90º vertically, and pull it up out of its socket.
To reassemble your device, follow these instructions in reverse order. You may also wish to replace the flushing box at this time.
Screw torques from the service manual have been included if you happen to have a torque screwdriver, but don’t worry about them if you don’t.
After reassembly, follow the following steps to reset the purge count in order to clear the “Ink Absorber Full” error:
- Plug the printer in and turn it on.
- Press the Home button (the house icon) on the front of the printer until the Maintenance Mode screen appears (approximately five seconds).
- Hold down the blank button at the bottom of the screen until a number keypad appears on the screen (approximately two seconds).
- Press *, 2, 8, 6 and 4 (you can use the onscreen keypad or the printer’s built-in keypad for this). The printer will beep and MAINTENANCE will appear on the screen.
- Press 8 and 0.
- Press the down arrow repeatedly until PURGE: (or FLUSHING:) appears on the screen.
- Press 2, 7, 8 and 3. The printer will beep and MAINTENANCE will again appear on the screen.
- Press 9 twice to exit maintenance mode and reboot the printer. You can also use this to start over if you make an error.
- Press 8 and 0.
50 weitere Nutzer:innen haben diese Anleitung absolviert.
51 Kommentare
Useful for dismantling the printer although my problem wasn’t with the waste ink component
Well, feel free to make a guide based on this one for whatever your problem was!
Calion -
Calion, you are my hero! The one place I’ve found where I can buy the replacement waste box for my Brother MFC-J4510DW does not provide directions on how to install it. And Brother itself offers neither the part nor the instructions. I thought I was going to have to buy a new printer until I came across your excellent report! Thanks so much for doing this!
You’re welcome! Very glad I could help out!
Calion -
Very informative and helpful :-)
Question could you fit a external waste ink tank ? what size are the waste ink tubes?
