Zum Hauptinhalt wechseln
MID-7006 Battery Replacement
Was du brauchst
  1. MID-7006 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 MID-7006 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to pull the screen away from the back cover.
  2. MID-7006 Battery Replacement: Schritt 2, Bild 1 von 2 MID-7006 Battery Replacement: Schritt 2, Bild 2 von 2
    • Once you have seperated the back plate and the screen from each other like so, you will then begin to lift the battery peeling it off of its sticky pads.
  3. MID-7006 Battery Replacement: Schritt 3, Bild 1 von 2 MID-7006 Battery Replacement: Schritt 3, Bild 2 von 2
    • Unplug the battery at the plug indicated by the plastic opening tool. (The best way to do this is to place a finger on both sides of the plug and pull out gently) Once you have removed the old battery, plug the new battery into the same plug the old one came from.
Abschluss
Texas Tech, Team 38-1, Bennett Fall 2016 Mitglied von Texas Tech, Team 38-1, Bennett Fall 2016
TTU-BENNETT-F16S38G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 157
