Zum Hauptinhalt wechseln
MSI Force GC30 V2 ABXY Buttons Replacement
Was du brauchst
  1. MSI Force GC30 V2 ABXY Buttons Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
    Frag FixBot
    Kommentar hinzufügen
  2. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 2, Bild 1 von 3 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 2, Bild 2 von 3 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
    Frag FixBot
  3. MSI Force GC30 V2 ABXY Buttons Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
    Frag FixBot
  4. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 4, Bild 1 von 1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
    Frag FixBot
  5. MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: Schritt 5, Bild 1 von 3 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: Schritt 5, Bild 2 von 3 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: Schritt 5, Bild 3 von 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
    Frag FixBot
  6. MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: Schritt 6, Bild 1 von 2 MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: Schritt 6, Bild 2 von 2
    • Remove the 7.1 mm-long Phillips #0 screw.
    • Remove the 7 mm-long Phillips #0 screw.
    Frag FixBot
  7. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 7, Bild 1 von 2 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 7, Bild 2 von 2
    • Remove the left/right bumper assembly.
    Frag FixBot
  8. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 8, Bild 1 von 2 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift the motherboard out of its casing and remove it.
    Frag FixBot
  9. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 9, Bild 1 von 2 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 9, Bild 2 von 2
    • Remove the ABXY button either by pulling them out or turning the controller the other side and letting the buttons fall out.
    Frag FixBot
  10. MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 10, Bild 1 von 3 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 10, Bild 2 von 3 MSI Force GC30 V2 ABXY Buttons Replacement: Schritt 10, Bild 3 von 3
    • Remove the ABXY button membrane by carefully lifting it off the motherboard.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 67
Insgesamt: 864
