Einleitung
In this guide we have a MSI Force GC30 V2, model number/name is MSI Force GC30 V2 and we are replacing the D-Pad (Directional Pad). The D-Pad is a directional controller for the controller itself or it could also be used for various other inputs. The D-Pad may become damaged with prolonged use or rough play. The MSI Force GC30 V2 also has an alternate D-Pad that comes with the controller you can use with this guide. One symptom of a bad D-Pad is no game input when pressing the D-Pad.
Was du brauchst
Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
Remove the six 9.2 mm-long Phillips #0 screws.
Insert an opening pick in the gap between the front and rear case.
Slide the pick around the perimeter of the controller while prying until it fully releases.
Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
Carefully remove both the right and left vibration motors from their housing.
Remove the 7.1 mm-long screw with a Phillips screwdriver.
Remove the 7 mm-long screw with a Phillips screwdriver.
Carefully lift the motherboard out of its housing.
Eine weitere Person hat diese Anleitung absolviert.
