Zum Hauptinhalt wechseln
MSI Force GC30 V2 Vibration Motor Replacement
Was du brauchst
  1. MSI Force GC30 V2 Vibration Motor Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
    Frag FixBot
    Kommentar hinzufügen
  2. MSI Force GC30 V2 Vibration Motor Replacement: Schritt 2, Bild 1 von 3 MSI Force GC30 V2 Vibration Motor Replacement: Schritt 2, Bild 2 von 3 MSI Force GC30 V2 Vibration Motor Replacement: Schritt 2, Bild 3 von 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
    Frag FixBot
  3. MSI Force GC30 V2 Vibration Motor Replacement, Battery: Schritt 3, Bild 1 von 1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
    Frag FixBot
  4. MSI Force GC30 V2 Vibration Motor Replacement: Schritt 4, Bild 1 von 1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
    Frag FixBot
  5. MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: Schritt 5, Bild 1 von 3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: Schritt 5, Bild 2 von 3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: Schritt 5, Bild 3 von 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 439
