Zum Hauptinhalt wechseln
MSI GE62 6QF Apache Pro RAM Replacement
Was du brauchst
  1. MSI GE62 6QF Apache Pro  RAM Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro  RAM Replacement, Bottom Case: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 4, Bild 1 von 3 MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 4, Bild 2 von 3 MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 4, Bild 3 von 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 5, Bild 1 von 2 MSI GE62 6QF Apache Pro  RAM Replacement: Schritt 5, Bild 2 von 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro  RAM Replacement, Battery: Schritt 6, Bild 1 von 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: Schritt 6, Bild 2 von 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: Schritt 6, Bild 3 von 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro  RAM Replacement, RAM: Schritt 7, Bild 1 von 2 MSI GE62 6QF Apache Pro  RAM Replacement, RAM: Schritt 7, Bild 2 von 2
    • Pull the metal tabs that hold the RAM in place away horizontally from the RAM stick, and slide the RAM out of the socket.
    • Repeat the same steps for the other RAM stick.
Abschluss
USF Tampa, Team S2-G3, Passmore Fall 2017 Mitglied von USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,937
