Zum Hauptinhalt wechseln
MSI GE62 6QF Apache Pro Battery Replacement
Was du brauchst
  1. MSI GE62 6QF Apache Pro Battery Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Battery Replacement, Bottom Case: Schritt 3, Bild 1 von 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Battery Replacement: Schritt 4, Bild 1 von 3 MSI GE62 6QF Apache Pro Battery Replacement: Schritt 4, Bild 2 von 3 MSI GE62 6QF Apache Pro Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Battery Replacement: Schritt 5, Bild 1 von 2 MSI GE62 6QF Apache Pro Battery Replacement: Schritt 5, Bild 2 von 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Battery Replacement, Battery: Schritt 6, Bild 1 von 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: Schritt 6, Bild 2 von 3 MSI GE62 6QF Apache Pro Battery Replacement, Battery: Schritt 6, Bild 3 von 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Justice Owens
604 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S2-G3, Passmore Fall 2017 Mitglied von USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Excellent guide! Very straightforward with very clear picture. I was able to replace my laptop battery using your tools and following your instruction! 10/10!
Carl Patterson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 6,245
