Einleitung
This guide will show how to replace the motherboard on the MSI Apache Pro 004 laptop.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Start with the bottom of the laptop facing up.
    • Start with the bottom of the laptop facing up.
  2. Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Abschluss
Alexander
Mitglied seit 19.02.2018
86 Reputation
1 Anleitung geschrieben
USF Tampa, Team S15-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 414
