Einleitung
This guide will show how to replace the motherboard on the MSI Apache Pro 004 laptop.
Was du brauchst
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
Remove the bottom plate
Remove the screw holding down the battery with a PH1 screwdriver.
Pull out the battery.
Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
Unfasten the 8 screws holding the motherboard in place.
Pull out the motherboard.
Ein Kommentar
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
