Was du brauchst
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
Remove the bottom plate
Remove the screw holding down the battery with a PH1 screwdriver.
Pull out the battery.
Open the laptop up as if you were going to use it.
Wedge a spudger in between the screen bezel and work it around to separate it.
Remove the bezel from the screen.
Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
