Zum Hauptinhalt wechseln
MSI GE62 Apache Pro 004 Screen Replacement
Was du brauchst
  1. MSI GE62 Apache Pro 004 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Screen Replacement: Schritt 2, Bild 1 von 2 MSI GE62 Apache Pro 004 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Screen Replacement: Schritt 3, Bild 1 von 3 MSI GE62 Apache Pro 004 Screen Replacement: Schritt 3, Bild 2 von 3 MSI GE62 Apache Pro 004 Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Screen Replacement, Screen: Schritt 4, Bild 1 von 2 MSI GE62 Apache Pro 004 Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Open the laptop up as if you were going to use it.
    • Wedge a spudger in between the screen bezel and work it around to separate it.
  5. MSI GE62 Apache Pro 004 Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the screws holding in the screen at the corners with a PH1 screwdriver.
    • Be very careful as the screen may tilt forward so make sure your hand is right is on the screen when the screw comes off.
  6. MSI GE62 Apache Pro 004 Screen Replacement: Schritt 6, Bild 1 von 3 MSI GE62 Apache Pro 004 Screen Replacement: Schritt 6, Bild 2 von 3 MSI GE62 Apache Pro 004 Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove the bezel from the screen.
    • Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
Abschluss
Samer Soukieh
209 Reputation
1 Anleitung geschrieben
USF Tampa, Team S15-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 2,133
