Zum Hauptinhalt wechseln
MSI GE62 Apache Pro 004 Speakers Replacement
Was du brauchst
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 2, Bild 1 von 2 MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 3, Bild 1 von 3 MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 3, Bild 2 von 3 MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: Schritt 4, Bild 1 von 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: Schritt 4, Bild 2 von 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: Schritt 4, Bild 3 von 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 5, Bild 1 von 2 MSI GE62 Apache Pro 004 Speakers Replacement: Schritt 5, Bild 2 von 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Abschluss
Majid Al Hashmi
283 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S15-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 1,494
