Zum Hauptinhalt wechseln
MSI GE62 Apache Pro 004 Web Camera Replacement
Was du brauchst
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 2, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 1 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 2 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: Schritt 4, Bild 1 von 1
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 1 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 2 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 3 von 3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 6, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 6, Bild 2 von 2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 7, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 7, Bild 2 von 2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
Abschluss
Majid Al Hashmi
283 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S15-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 850
