Einleitung
The Optical Drive replacement is easy, just a note though, our Optical Drive did not come with the bezel attached. When the drive has the bezel attached the back panel does not have to come off. Instead a single screw on the back panel would be removed and the drive would slide out.
Was du brauchst
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
Using your fingers, gently loosen the edges of all four sides of the back cover.
Gently pull off the back cover.
Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
Carefully slide the Optical Drive off of the SATA connector.
The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
So you don’t have power running through it while working on it.
