Einleitung
Is your wireless card not working? Here's a guide to replace it. Make sure you follow each step accordingly and carefully replace the wireless card.
Was du brauchst
Find the unlock tab located on the upper right side of the device, then slide it to the right.
Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
Using a Phillips #00 screwdriver, remove the one 2 mm screw that is holding the wireless card in place.
Remove the wires connecting to the wireless card by pinching around the base where they connect, then carefully disconnect them.
2 weitere Personen haben diese Anleitung absolviert.
