Einleitung
Is your MSI GP60 2PE Leopard not turning on or not charging properly? Here's a guide to replace the battery. No tools are needed to replace the MSI GP60 2PE Leopard battery.
Find the unlock tab located on the upper right side of the device, then slide it to the right.
Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
