Zum Hauptinhalt wechseln
MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement
Was du brauchst
  1. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 3, Bild 1 von 2 MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement, Battery: Schritt 4, Bild 1 von 1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 5, Bild 1 von 1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 6, Bild 1 von 2 MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 6, Bild 2 von 2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement, Speaker: Schritt 7, Bild 1 von 2 MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement, Speaker: Schritt 7, Bild 2 von 2
    • Disconnect the wires connnecting the speaker to the motherboard by grasping the portion of the cable covered in black shielding, and carefully pulling it horizontally away from the port it is connected to.
    • Be careful not to pull the cable too hard and bend the port on connecting the speakers to the motherboard.
  8. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 8, Bild 1 von 2 MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 8, Bild 2 von 2
    • Use the screwdriver to unscrew the 4 1.5mm Phillips #0 screws connecting the speakers to the frame of the device.
    • There are 2 individual speaker modules, with 2 screws each.
  9. MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 9, Bild 1 von 2 MSI GS60 Ghost Pro 4K Gold Edition Speaker Replacement: Schritt 9, Bild 2 von 2
    • Carefully pull both the left and right speaker modules out of the computer.
Abschluss
nonEdward666
340 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G2, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S2-G2, Julie Fall 2017
UMASSD-JULIE-F17S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 393
