Einleitung
This guide will detail how to replace the Wi-Fi card inside the MSI GS60 Ghost Pro 4K Gold Edition.
Was du brauchst
Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
Using the plastic opening tools, separate the back panel from the rest of the device.
Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
Use the screwdriver to unscrew the 0.5mm Phillips #0 screw holding the Wi-Fi card in place.
