Zum Hauptinhalt wechseln
MSI GS66 Stealth 11UE-007 Cooling Fan Replacement
Was du brauchst
  1. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, MSI GS66 Stealth 11UE-007 CPU Thermal Paste Replacement: Schritt 1, Bild 1 von 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device for any outlet.
  2. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 2, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 2, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    • Remove eight 10mm Phillips J1 screws.
    • Remove one 7mm Philips J1 screw from the center bottom of backplate.
  3. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 3, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 3, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  4. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the wires from the cooling fan.
  5. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 5, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the two wires from the Wi-Fi card.
  6. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 6, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 6, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the nine 6 mm screws.
  7. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 7, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Remove the tape connecting the fans to the fan housing.
  8. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement: Schritt 8, Bild 1 von 1
    • Lift up the cooling unit like it is hinged at the back.
    • Replace thermal paste.
  9. MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: Schritt 9, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: Schritt 9, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Cooling Fan Replacement, Cooling Fan: Schritt 9, Bild 3 von 3
    • Remove the fans
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Alex Robinson
1.061 Reputation
6 Anleitungen geschrieben
University of Memphis, Team 1-4, Sneed Fall 2023 Mitglied von University of Memphis, Team 1-4, Sneed Fall 2023
UM-SNEED-F23S1G4
4 Mitglieder
2 Kommentare
Has anyone found a solution to this issue yet, that doesn't require micro soldering`````````````Jorge Rodriguez.
Rachel Kelley - Antwort
Please correct order of pictures. Description is correct but you put wrong pictures in spots. WiFi adapter isn't tape holding the heatsink assembly down.
John Banks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 33
Letzte 30 Tage: 183
Insgesamt: 1,821
