Zum Hauptinhalt wechseln
MSI GS66 Stealth 11UE-007 Speakers Replacement
Was du brauchst
  1. MSI GS66 Stealth 11UE-007 Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device.
  2. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 4, Bild 1 von 1
    • Remove one 7 mm Phillips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 5, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 5, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 6, Bild 1 von 1
    • Peal back metallic tape on the right side of the USB port.
  7. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 7, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 7, Bild 2 von 2
    • Remove three 6 mm Phillips #1 screws.
  8. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 8, Bild 1 von 1
    • Use the tip of the spudger or your fingernail to gently push out the white connector.
  9. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 9, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 9, Bild 2 von 2
    • Remove the battery from the device.
  10. MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: Schritt 10, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Speakers Replacement, Speakers: Schritt 10, Bild 2 von 2
    • Disconnect the speaker power using the tip of the spudger or fingernail to gently push on either side of the connector.
  11. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 11, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 11, Bild 2 von 2
    • Lift up the clip using the spudger.
    • Pull out the ribbon cable away from the clips.
  12. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 12, Bild 1 von 2 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 12, Bild 2 von 2
    • Remove the wire from the channel it's sitting in.
  13. MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 13, Bild 1 von 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 13, Bild 2 von 3 MSI GS66 Stealth 11UE-007 Speakers Replacement: Schritt 13, Bild 3 von 3
    • Lift up the left and right speakers.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Alex Robinson
1.057 Reputation
6 Anleitungen geschrieben
University of Memphis, Team 1-4, Sneed Fall 2023 Mitglied von University of Memphis, Team 1-4, Sneed Fall 2023
UM-SNEED-F23S1G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 122
