Zum Hauptinhalt wechseln
MSI GT62VR 6RD Dominator Battery Replacement
Was du brauchst
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: Schritt 1, Bild 1 von 2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: Schritt 2, Bild 1 von 2 MSI GT62VR 6RD Dominator Battery Replacement: Schritt 2, Bild 2 von 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: Schritt 3, Bild 1 von 3 MSI GT62VR 6RD Dominator Battery Replacement: Schritt 3, Bild 2 von 3 MSI GT62VR 6RD Dominator Battery Replacement: Schritt 3, Bild 3 von 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Abschluss
Rebekah Johnson
147 Reputation
1 Anleitung geschrieben
Ein Kommentar
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,953
