Zum Hauptinhalt wechseln
MSI GT62VR 6RD Dominator Hard Drive Replacement
Was du brauchst
  1. MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Hard Drive Replacement: Schritt 2, Bild 1 von 3 MSI GT62VR 6RD Dominator Hard Drive Replacement: Schritt 2, Bild 2 von 3 MSI GT62VR 6RD Dominator Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool into the seam of the back cover
    • Pry the cover up until clips release.
    • Slide the plastic opening tool around the laptop until cover is fully removed.
  3. MSI GT62VR 6RD Dominator Hard Drive Replacement: Schritt 3, Bild 1 von 2 MSI GT62VR 6RD Dominator Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the two screws securing the hard drive to the laptop.
    • Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Wiggle it backwards slowly until it is unplugged.
    • Slide out from under the cover towards the battery.
Abschluss
Adrian Nelson
270 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 666
