Einleitung
This troubleshooting guide will give step-by-step instructions on how to replace the M.2 SSD on your MSI GT62VR 6RD Dominator laptop. This troubleshooting guide has no special requirements or potential hazards. It is recommended to replace your SSD if you experience a few of the following: data corruption, slow read/write speeds, bad sector errors. Little to no risk of injury is involved to complete these guide steps and is not time consuming to complete.
Was du brauchst
Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
Insert the plastic opening tool into the seam on the backplate of the laptop.
Pry the back plate up.
Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
Remove the single 1.2mm screw securing the SSD to the laptop using the JIS #0 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Isn’t that an M.2 Drive not a GPU? the GPU is in the top right. under the heat pipes.
