Einleitung
If your MSI GT70 MS-1763 has memory issues – undetected RAM, memory crashes, startup failure, or simply running out of memory – this guide will provide instructions for replacing the RAM.
Before using this guide, be sure the computer issues are related to the RAM. If you are having random crashes, boot your computer in safe mode and see if the issue persists. There is also software such as MemTest86 which diagnoses your computer’s RAM to confirm the issue is related to the RAM.
Before beginning, make sure to completely power off your device and disconnect it from the charger.
Was du brauchst
Release the safety latches that hold the battery in place. The left latch will stay moved up, while the right side is spring activated and will have to be held.
While holding up the left latch, use a Jimmy and slide the old battery out of its compartment.
Remove all twelve 4 mm Phillips #0 screws from the back of the laptop.
Remove the back cover.
Using a Jimmy, remove the outer cover around the keyboard.
Remove the ribbon cable from the ZIF connector on the underside of the top cover.
Using a Phillips #0 screwdriver, remove the five 3 mm screws at the top of the keyboard.
Flip the laptop over and disconnect the data cable from the ZIF connector on the bottom right.
You can now turn the laptop back over and remove the keyboard.
Pull the safety latches on either side of the RAM away from each other.
Remove the RAM, maintaining the angle at which it rests.
Eine weitere Person hat diese Anleitung absolviert.
