Einleitung
CD drive not working properly? CD drive not functioning properly and refusing to come out? This guide will take you through how to remove the CD drive.
Was du brauchst
Remove the indicated seven (7) 6 mm Phillips #0 screws for the back cover.
Lift metal cover gently, using the tab like indent located where the arrow is pointed.
This should expose the inside of the CD drive.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
