Einleitung
If you experience any issues with fans not working properly or not functioning at all, this guide will help you remove them from the computer for inspection or replacement.
Was du brauchst
Remove the seven 6 mm Phillips #00 screws on the back cover of the laptop with the PH0 Bit screwdriver.
Lift the back cover off by lifting by the tab on the bottom of the cover as indicated.
Unscrew a total of four 10mm Philips #00 screws (two screws per fan) as indicated.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
