Einleitung
How to access, locate, and replace your MSI GT75VR 7RF Titan Pro cooling fan if it breaks.
Was du brauchst
Using the Phillips #0 screwdriver, unscrew each of the four screws on the back of the laptop case. The screws are 0.5 inches long.
Disconnect the battery cable. Pry the battery out using the black nylon spudger.
Using the Phillips #0 screwdriver, unscrew the two black 0.25 inch screws located on the sides of the cooling fan.
Unplug the unit.
