Zum Hauptinhalt wechseln
MSI GT75VR 7RF Titan Pro RAM Card Replacement
Was du brauchst
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: Schritt 1, Bild 1 von 1
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 2, Bild 1 von 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 2, Bild 2 von 2
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 4, Bild 1 von 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 4, Bild 2 von 2
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 5, Bild 1 von 1
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: Schritt 6, Bild 1 von 1
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
Abschluss
Jack Crumpton
241 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 649
