Einleitung
SSD/Hard Drive are both crucial components to insure your computer system is able to save important data and memory. A SSD or Hard Drive can be corrupted or also can be in need of a upgrade. To improve these parts new cards must be installed.
Was du brauchst
Remove the four rear screws using the Phillips #0 screwdriver from the laptop as shown. The screws are 0.5 inches long.
Using the black nylon spudger, carefully remove the rear cover from the laptop.
Carefully unplug the battery and remove it from the laptop. This will be held down with adhesive, but can be safely removed once unplugged.
Using the Phillips #0 screwdriver, remove each screw from the heatsink and remove it.
Using the Phillips #0 screwdriver, remove each screw from the SSD card units, then unplug and remove them. The screws are 0.25 inches long.
Remove all screws from the back of the hard drive using the Phillips #0 screwdriver, then lift up and unplug the unit. Screws are 0.15625 inches long.
Eine weitere Person hat diese Anleitung absolviert.
