Einleitung
This guide is for removing the back cover of the MSI MS-1782.
Was du brauchst
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Use an iFixit opening pick to unclip the bottom cover.
After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
