Zum Hauptinhalt wechseln
MSI MS-1782 Back Cover Replacement
Was du brauchst
  1. MSI MS-1782 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: Schritt 2, Bild 1 von 3 MSI MS-1782 Back Cover Replacement: Schritt 2, Bild 2 von 3 MSI MS-1782 Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Abschluss
Joshua Pizzo
438 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 241
