Einleitung
This guide will show you how to replace the Wi-Fi card in a MSI MS-1782 laptop. If you are having trouble connecting to the Wi-Fi after exhausting all software fixes, use this guide to replace the Wi-Fi card. There are also steps you should do before the disassembly, like unplugging the battery.
Was du brauchst
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Use an iFixit opening pick to unclip the bottom cover.
After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Use the flat end of a spudger to detach the two antenna cables from the Wi-Fi card.
Remove the 5 mm screw holding the Wi-Fi card in place with a JIS #1 screwdriver.
To reassemble your device, follow these instructions in reverse order and make sure you put the antenna wires back in the correct order.
