Zum Hauptinhalt wechseln
MSI PR600 MS-16372 Key Replacement
Was du brauchst
  1. MSI PR600 MS-16372 Key Replacement, Key: Schritt 1, Bild 1 von 1
    • Before you begin this replacement, make sure to turn the computer off to prevent future problems from occurring.
    • Start by flipping the laptop upside down and shake it gently to release excess debris.
  2. MSI PR600 MS-16372 Key Replacement: Schritt 2, Bild 1 von 1
    • Place flathead screwdriver underneath the faulty key.
    • Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
  3. MSI PR600 MS-16372 Key Replacement: Schritt 3, Bild 1 von 1
    • Gently brush off any loose particles that could be found underneath the key.
  4. MSI PR600 MS-16372 Key Replacement: Schritt 4, Bild 1 von 1
    • Align key to the center of the button and press down until you hear it click.
    • If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
Abschluss
Lauren Mewes
361 Reputation
3 Anleitungen geschrieben
UC Davis, Team S4-G8, Lore Fall 2018 Mitglied von UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 303
