Einleitung
This guide will help you fix a key that is not working when you push down on it. Instead of pushing down harder or repeatedly pushing down on the key, this guide will serve as a step-by-step guide to clean underneath the key.
Was du brauchst
Start by flipping the laptop upside down and shake it gently to release excess debris.
Place flathead screwdriver underneath the faulty key.
Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
Align key to the center of the button and press down until you hear it click.
If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
