Zum Hauptinhalt wechseln
MSI VR601 WiFi card Replacement
Was du brauchst
  1. MSI VR601 WiFi card Replacement, Open the back cover: Schritt 1, Bild 1 von 2 MSI VR601 WiFi card Replacement, Open the back cover: Schritt 1, Bild 2 von 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: Schritt 2, Bild 1 von 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: Schritt 2, Bild 2 von 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: Schritt 3, Bild 1 von 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Abschluss
Master Techs Mitglied von Master Techs
Community
312 Mitglieder
1.330 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 11
Insgesamt: 86
