Was du brauchst
First things first : you'll need a reasonably dead Mac Cube power supply
The first step is to separate these two end-caps
Each of them has 2 very strong (and equally brittle) clips holding it in place
The only way to access these clips is through the ventilation holes, .. how convenient !
It's enough to unhook 1 clip per side, and one of the clips cannot be unhooked, as it's blocked by some black paper plastic rubber thingy
In case you have something thin and strong enough to do this without enlarging the holes: please leave a comment down below !
I drilled through the existing holes to make them large enough for a fittingly stiff screw driver
Once you've enlarged your holes, it's just a matter of carefully prising these clips free
Since peeping through a 3mm hole doesn't give one the best visibility, here's also a photo of the power supply board, so you know what to look out for ;)
Correctly assuming you've gotten rid of all the plastic surrounding the metal chassis, it's high time to open a bottle of something !
Unclip metallic end-caps with a relatively skinny flat-head screw driver
Now, the last step is to unhook the two halves of the metal chassis from each other - with the correct motion, this happens very easily
Firmly press on the top half (the bottom has the PCB laying right against it) whilst prising with a flat-head screw driver at the seam: there's 3 metal clips to unhook on each side
And you're done !
Congrats !
Congrats !
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Excellent walk-through of the steps, with very kind and generous warnings. I found this VERY helpful, as I own two working G4 Cubes, with no power supplies. I’m looking for broken “bricks” to repair and finally re-use my Cubes.
Thanks mate ! This will help to get my Cube alive again : -)
