Zum Hauptinhalt wechseln
Mac Mini Mid 2010 Fan Replacement
Was du brauchst
  1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Mac Mini Mid 2010 Fan Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac Mini Mid 2010 Fan Replacement: Schritt 2, Bild 1 von 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac Mini Mid 2010 Fan Replacement, Fan: Schritt 3, Bild 1 von 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac Mini Mid 2010 Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Mac Mini Mid 2010 Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
Abschluss
23 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
How do you know the order of the wires when placing the 4 wires back onto the motherboard?
Communications Department - Antwort
The connector is a snap in / snap out or more properly lift out connector. The connector goes back in only one way with the 4 pins aimed towards the wifi icon. To get it out you GENTLY lift the wires. I used my fingernail under the wires as they went from the fan into the connector.
Mike Stark - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 47
Insgesamt: 16,006
