Werkzeuge
Ersatzteile
Find the 2 pull tabs and use them to pull out the CPU tray and place them on the table.
Use a hex wrench to unscrew the spring-loaded screw on the CPU heatsink and lift up until the heatsink if fully disconnected.
On the bottom of the heatsink will be a copper pad that comes in contact with the CPU. Use a paper towel to wipe off all the remaining thermal paste.
Clean all of the thermal paste on the CPU and lift the metal bar up and pull the bracket back.
Gently pull out the old CPU with thumb and pointer finger and then place it towards the side.
Inspect the cpu socket and other connectors for dust and debris and blow away if necessary.
Place the new cpu in with a touch of thermal paste at the top.
Do everything in reverse operation
Ein weiterer Nutzer hat diese Anleitung absolviert.
2 Kommentare
@beanman56 , you're not bothering me. This is exactly what I'm here for. I just wish I could get back to you sooner, but we've been a little busy. Let me look into this a bit more and I will get back to you.
