Zum Hauptinhalt wechseln
Mac Pro 2009-2012 Case Replacement
Was du brauchst
  1. Mac Pro 2009-2012 Case Replacement, Open the Case: Schritt 1, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Open the Case: Schritt 1, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Open the Case: Schritt 1, Bild 3 von 3
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Case Replacement, Remove the side panel: Schritt 2, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Remove the side panel: Schritt 2, Bild 2 von 2
    • Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
  3. Mac Pro 2009-2012 Case Replacement, Remove the hard drives: Schritt 3, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Remove the hard drives: Schritt 3, Bild 2 von 2
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: Schritt 4, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: Schritt 4, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: Schritt 4, Bild 3 von 3
    • Pull the DVD drives towards you, just like the hard drives.
  5. Mac Pro 2009-2012 Case Replacement, Remove the CPU board: Schritt 5, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: Schritt 5, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: Schritt 5, Bild 3 von 3
    • Press both latches to unlock the bracket and then pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: Schritt 6, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: Schritt 6, Bild 2 von 2
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): Schritt 7, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): Schritt 7, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): Schritt 7, Bild 3 von 3
    • On the power supply there is a button, press it to move the power supply to the left (see picture)
    • Then pull the graphics card towards you to take it out of the box
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): Schritt 8, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): Schritt 8, Bild 2 von 2
    • Disconnect the PCI-e cables from the motherboard
    • This step is optional depending on your Mac Pro
  9. Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: Schritt 9, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: Schritt 9, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: Schritt 9, Bild 3 von 3
    • With a screwdriver unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you
  10. Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: Schritt 10, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: Schritt 10, Bild 2 von 2
    • Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: Schritt 11, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: Schritt 11, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: Schritt 11, Bild 3 von 3
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: Schritt 12, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: Schritt 12, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: Schritt 12, Bild 3 von 3
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: Schritt 13, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: Schritt 13, Bild 2 von 2
    • Similar to the top remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: Schritt 14, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: Schritt 14, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: Schritt 14, Bild 3 von 3
    • Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step or you risk damaging your connectors on the motherboard and make unusable fans and speaker!
  15. Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: Schritt 15, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: Schritt 15, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: Schritt 15, Bild 3 von 3
    • Pull the CPU support towards you
    • Do not use force during this step,It it does not come out easily ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: Schritt 16, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: Schritt 16, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: Schritt 16, Bild 3 von 3
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Attention, it is necessary to remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Case Replacement, Remove the expansion card: Schritt 17, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: Schritt 17, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: Schritt 17, Bild 3 von 3
    • Unscrew the 6 screws that hold the card in place.
    • Be careful to unplug the power cable on the card !!
  18. Mac Pro 2009-2012 Case Replacement, Remove the cover: Schritt 18, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the cover: Schritt 18, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the cover: Schritt 18, Bild 3 von 3
    • unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Case Replacement, Unplug the power supply: Schritt 19, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: Schritt 19, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: Schritt 19, Bild 3 von 3
    • Push on both knobs to remove the power connector
    • Do not use force, if you push on the knows it should come out without force.
  20. Mac Pro 2009-2012 Case Replacement, Separate the power supply: Schritt 20, Bild 1 von 2 Mac Pro 2009-2012 Case Replacement, Separate the power supply: Schritt 20, Bild 2 von 2
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Case Replacement, Remove the power supply: Schritt 21, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the power supply: Schritt 21, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the power supply: Schritt 21, Bild 3 von 3
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: Schritt 22, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: Schritt 22, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: Schritt 22, Bild 3 von 3
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Case Replacement, Remove the mother board: Schritt 23, Bild 1 von 3 Mac Pro 2009-2012 Case Replacement, Remove the mother board: Schritt 23, Bild 2 von 3 Mac Pro 2009-2012 Case Replacement, Remove the mother board: Schritt 23, Bild 3 von 3
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Case Replacement, Change the case: Schritt 24, Bild 1 von 1
    • Follow the steps in reverse to resemble.
Abschluss
To resemble, follow the instructions in the reverse order.
21 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
Beginne zu übersetzen ›
remitouch
979 Reputation
1 Anleitung geschrieben
6 Kommentare
Bonjour, j’ai un mac pro 5,1 de 2010 dont les clapets (ou les trappes, j’ignore le terme exact) de la baie des lecteurs de disques restent ouverts à chaque fois qu’ils sont actionnés. Je n’ai pas réussi à les démonter, et les 2 gouttes de 3 en 1 sur les glissières latérales n’ont rien changé au problème. Je n’ai trouvé aucun tutoriel, ni même aucune occurrence de ce problème sur le web. Pourriez-vous me donner quelques conseils ? Merci.
Gabriel Fracque - Antwort
Amazing explanations and perfect picture track on each move made.
Thanks much - this was very helpful :)
Dennis.
Dennis OBrien - Antwort
Hello sir , I have a problem with my Mac Pro 5,1 mid 2010 Xeon 6core Cpu 64 GB Ram RX580
I erase SSD Hard Drive and I want to reinstall mojave OS and it does not work still appear ‘Missing Operating System’
I try to use all commends on startup like (Option) (Commend+R) (Option+Commend+R)(Option+Commend+R+P) and more commends
but nothing work with it … please I want help . I need your help please , please …
Hussain Khan - Antwort
You’d probably get an answer a lot quicker if you just posted that as a question.
Evan -
Thanks for posting this guide!
I used it to replace all the cooking fans in my macpro5,1. Worked great!!
Andrew Clark - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 11
Letzten 7 Tage: 83
Letzten 30 Tage: 420
Insgesamt: 20,341
