Zum Hauptinhalt wechseln
Einleitung
Removing a graphics card from this version of the Mac Pro isn’t as simple as pulling the card out of the PCI slot.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. The screws are spring-mounted and will stay attached to the cover. You can remove them by hand, although a screwdriver may be needed to start. When reassembling, pay attention to the notch at the top. The cover should slide into this notch.
    • The screws are spring-mounted and will stay attached to the cover. You can remove them by hand, although a screwdriver may be needed to start.
    • When reassembling, pay attention to the notch at the top. The cover should slide into this notch.
  2. If the card is long enough to reach the slots in the fan casing, or the card is hooked into the lockbar next to the PCI ports, you need to slide the cover on the fan casing over. Press the release button and slide the casing to the left. This also moves the lockbar.
    • If the card is long enough to reach the slots in the fan casing, or the card is hooked into the lockbar next to the PCI ports, you need to slide the cover on the fan casing over.
    • Press the release button and slide the casing to the left.
    • This also moves the lockbar.
  3. The connectors require a fair amount of force to remove. Be careful! The connectors require a fair amount of force to remove. Be careful!
    • The connectors require a fair amount of force to remove. Be careful!
  4. Pull the card straight out (Don't wiggle it!) When reinstalling the card, make sure the bracket fits over the screw threads. When reinstalling the card, make sure the bracket fits over the screw threads.
    • Pull the card straight out (Don't wiggle it!)
    • When reinstalling the card, make sure the bracket fits over the screw threads.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Taylor
163 Reputation
1 Anleitung geschrieben
Ein Kommentar
I was wondering if anyone knows if Sapphire Radeon video cards are repaired and who can that be
dawudi88 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 7
Letzten 7 Tage: 40
Letzten 30 Tage: 191
Insgesamt: 589
