Zum Hauptinhalt wechseln
Mac Pro 2009-2012 PCIe Card/GPU Replacement
Was du brauchst
  1. Mac Pro 2009-2012 PCIe Card/GPU Replacement, PCIe Card: Schritt 1, Bild 1 von 1
    • Lift the latch
    • Remove the side panel
  2. Mac Pro 2009-2012 PCIe Card/GPU Replacement, Remove PCI bracket cover: Schritt 2, Bild 1 von 2 Mac Pro 2009-2012 PCIe Card/GPU Replacement, Remove PCI bracket cover: Schritt 2, Bild 2 von 2
    • The screws are spring-mounted and will stay attached to the cover. You can remove them by hand, although a screwdriver may be needed to start.
    • When reassembling, pay attention to the notch at the top. The cover should slide into this notch.
  3. Mac Pro 2009-2012 PCIe Card/GPU Replacement, Release card from support slots or lock bar: Schritt 3, Bild 1 von 3 Mac Pro 2009-2012 PCIe Card/GPU Replacement, Release card from support slots or lock bar: Schritt 3, Bild 2 von 3 Mac Pro 2009-2012 PCIe Card/GPU Replacement, Release card from support slots or lock bar: Schritt 3, Bild 3 von 3
    • If the card is long enough to reach the slots in the fan casing, or the card is hooked into the lock bar next to the PCI ports, you need to slide the cover on the fan casing over.
    • Press the release button and slide the casing to the left.
    • This also moves the lock bar.
  4. Mac Pro 2009-2012 PCIe Card/GPU Replacement, Slide card out of PCI slot: Schritt 4, Bild 1 von 3 Mac Pro 2009-2012 PCIe Card/GPU Replacement, Slide card out of PCI slot: Schritt 4, Bild 2 von 3 Mac Pro 2009-2012 PCIe Card/GPU Replacement, Slide card out of PCI slot: Schritt 4, Bild 3 von 3
    • Pull the card straight out
    • When reinstalling the card, make sure the bracket fits over the screw threads.
    • Don't wiggle it! if you do so then you might damage the card or the slot
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Taylor
223 Reputation
1 Anleitung geschrieben
Ein Kommentar
I was wondering if anyone knows if Sapphire Radeon video cards are repaired and who can that be
dawudi88 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 47
Letzten 30 Tage: 259
Insgesamt: 3,208
