Einleitung
Use this guide to replace either of the dual graphics cards in your Mac Pro. The procedure is shown on one card, but it is essentially identical for either.
When you're replacing your card, be sure to reapply a layer of thermal compound.
Before beginning any work on your Mac Pro: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  1. Slide the lock switch to the right, to the unlocked position. Slide the lock switch to the right, to the unlocked position.
    • Slide the lock switch to the right, to the unlocked position.
  2. Lift the outer case straight up off the Mac Pro. It may help to push down on the center of the fan while lifting the case up. It may help to push down on the center of the fan while lifting the case up.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. The fan assembly is attached to the rest of the computer by two cables on the IO board side. Tilt the assembly up away from the IO board.
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Du bist ein Genie!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  8. Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board. Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  9. Disconnect the fan assembly antenna cable from the IO board.
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  10. Flip the Mac Pro upside down, 180 degrees. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  11. Carefully lift the lower case up and remove it from the Mac Pro. Carefully lift the lower case up and remove it from the Mac Pro.
    • Carefully lift the lower case up and remove it from the Mac Pro.
  12. Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection. Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  13. Gently separate the other side as well. Flip the connector up and out of the way of the graphics card. Flip the connector up and out of the way of the graphics card.
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
  14. Remove the two 6.6 mm T9 Torx Security screws securing the GPU to the Mac Pro.
    • Remove the two 6.6 mm T9 Torx Security screws securing the GPU to the Mac Pro.
    • These screws fit into power cables behind the GPU. Be careful not to over-tighten and twist the cables.
  15. Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
    • Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
  16. Remove the GPU heat sink bracket.
    • Remove the GPU heat sink bracket.
  17. The graphics card is now held onto the central heat sink by thermal compound. You may need to pry very gently with a spudger to separate the card from the heat sink. Remove the graphics card from the heat sink.
    • The graphics card is now held onto the central heat sink by thermal compound.
    • You may need to pry very gently with a spudger to separate the card from the heat sink.
    • Remove the graphics card from the heat sink.
  18. During reassembly, be sure to clean off and replace the thermal compound. Use our Applying Thermal Paste guide if you require assistance.
    • During reassembly, be sure to clean off and replace the thermal compound. Use our Applying Thermal Paste guide if you require assistance.
    • Repeat this procedure if you wish to remove the secondary graphics card.
Abschluss
19 weitere Nutzer haben diese Anleitung absolviert.
Andrew Optimus Goldberg
403.037 Reputation
412 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
109 Mitglieder
7.746 Anleitungen geschrieben
hey! is it possible to upgrade the GPU or is this just for replacing exactly the same part?
Ben - Antwort
I am guessing you can upgrade them with OEM parts, but where would we find them?
Fernando Bernardino -
I have the D300s, and would like to upgrade to the D500s or D700s. Where might I find the replacement graphics cards? Also, any recommendations on service providers who would do this procedure?
Chris M Balz - Antwort
I'd love to know this as well. The only reason I picked up the ,ad pro was the potential for upgrades. As it turns out D300s are crap. I can't even run boot camp properly.
jerimiahy -
Is it possible to put Nividia cards in?
Dave Rickards - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 17
Letzte 7 Tage: 123
Letzte 30 Tage: 638
Insgesamt: 50,916
