Einleitung
Mac Pro Mediados 2009 8 Core
Was du brauchst
Tablero de la placa y tablero del panel ligado por el tablero del panel al cable del tablero
Antena Bluetooth conectada a la tarjeta en el tablero de la placa. Uno debe tener cuidado por que si no esta conectada la antena necesita ser conectada para no causar cortocircuito en el panel del tablero de la placa.
Una vista del botón del encendido que se necesita conectar en el panel frontal.
Ventilador derecho en la jaula del procesador. Recuerde, dos clips para separar el ventilador. Arriba y abajo.
Unidad con el PSU, tablero plano, tablero de placa, tablero del panel frontal.
100%
Miguel hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
23 Kommentare
It is socket-b(LGA 1366)
I think it is easy to upgrade your CPU
It should be easy to upgrade a single-cpu Pro, they use standard lidded Xeons. I am planning on upgrading to W3690s in a couple of 4,1 machines that have had their firmware flashed to 5,1.
Please let me know how you handle that upgrade!! Or add a tutorial id vey much like to see that and maybe follow suit but im not very savy with these upgrades
Will -
Is it possible to easily remove and service right processor fan (the back one)? It makes too much noise, so needs some oil apparently. I didn't find any way to remove it.
