Einleitung
Use this guide to replace the PCIe SSD cable in the SSD-only or Fusion drive models of the Mac mini Late 2014.
Was du brauchst
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
Carefully pull the antenna cable out from the gap between the power supply and case.
Carefully lift the SSD out of the case without scratching or touching the gold contacts.
Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
Use the flat end of a spudger to lift the PCIe SSD connector straight up off of its connector on the logic board.
Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
28 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Where i can buy the PCIe SSD card?
Where i can buy the PCIe SSD card, someone?
I can supply these cables. Please reply to this thread.
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
