Einleitung
Use this guide to easily remove or replace the plastic bottom cover on your Mac mini.
Was du brauchst
Use an opening tool to pry the bottom cover up off of the Mac mini.
Lift and remove the bottom cover.
Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
Then, press down on the cover to snap its three hidden clips into place.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Check eBay for unibody Mac mini bottom covers. You can also 3D print one if you want to.
