Einleitung
Replace a faulty Bluetooth antenna to regain Bluetooth range.
Was du brauchst
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Remove the single Phillips screw securing the Bluetooth board to the internal frame.
Lift the Bluetooth board off the internal frame and use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
Pull the Bluetooth antenna cable out from underneath all the cables connected to the interconnect board.
Remove the Bluetooth antenna by pushing up on both sides of the board as close to the center post as possible.
Remove the Bluetooth antenna from the internal frame.
5 weitere Personen haben diese Anleitung absolviert.
